mad steering wheel shake
maxpowers
Post by maxpowers »
all the time,
it was just a bit, a wobble when accellerating, and a little vibration above 80kph,
but just had the wheels rotated and now its real bad, I actually meant to get them to check and balance or just spin em and see if ones warped or something, but forgot, is that the most likely culprit, bung wheel/s
or is it something more sinister. suggestions welcome. thanks.
no they are not original, but they have been taking me up and down the seatosky race way for 2.5 years, and it was third world.
session the gnar
snelson
Vehicle: 92 Delica Exceed
Re: mad steering wheel shake
Post by snelson »
Hey Max, I had the exact same problem, got my front driver side tire balanced (the guy at the shop said it was a real bugger to balance). It helped big time, but I stll had a faint wobble so I rotated the fronts to the back myself, and the shake was gone.
I'd swap them yourself, just to see if there's an instant difference, and if so, then have the wheel balanced or replaced.
Paule
Vehicle: 1997 L300 Active World
Post by Paule »
First thing I would check would be balancing and alignment... But if it had been happening before you rotated then....?
Edit:
Damn, I'm too slow.
Worn balljoints and tierods will cause wobbling as well.
I'd look at the tires first.
