When starting from cold my primary glow circuit works as it should and the engine starts, but it quickly becomes rough and then struggles to run smoothly for about 5 minutes. After this it's as sweet as anything (see here for why 8-)) I've tried jumping a cable from my battery to my glow plugs AFTER the engine has started and the lumpy start disappears within seconds leaving a very nice sounding engine! I cannot hear the secondary glow relay clicking on and off (as it has done on previous l300's) straight after starting, but it does kick in 20 minutes later when i'm driving along happily. It then decides to click on and off in rapid and random succession.
I've read a few similar stories and wondered if anyone has found the cure of 'The Dance of Glow Solenoid #2'?!
I have read Mystery Machine's diagnostic guides here and here and worked through the diagnostics. The only finding from this was that the dropping resistor read about 300mOhms rather than the 150mOhms on Bruce's guide.
Does anyone with a spare moment fancy whipping the cover off behind the driver's seat and measuring the resistance on their super-quick glow dropping resistor (shown on the RIGHT, below)
The best way is to disconnect it by disconnecting the green plug from the end of the resistor wires and putting a multimeter across the two pins.
Would be grateful if anyone gets the chance. Cheers
