1995 L300
after oil
1995 L300
Post by after oil »
i just bought from an auction a grade four February 1995 L300 low roof. i wonder if i can expect anything updated/upgraded from a '95 model...
Re: 1995 L300
Post by Green1 »
after oil wrote:i just bought from an auction a grade four February 1995 L300 low roof. i wonder if i can expect anything updated/upgraded from a '95 model...
from your 93 they will have changed a few things:
- water cooled turbo instead of oil cooled
- removed hand throttle control
not sure what else might have changed...
impalator
Vehicle: L300
Re: 1995 L300
Post by impalator »
Interesting... I have a 1994 L300 (must have been put on the road in 1993 - but is already a 1994 model-year - i.e. Watercooled turbo and no hand-throttle)...
Does anybody have any idea as to the advantages of a watercooled turbo vs. a non-watercooled or oilcooled turbo? Won't it be running as hot?
Thanks for any input...
Chris
Vehicle: -
Re: 1995 L300
Post by fexlboi »
Green1 wrote:not sure what else might have changed...
quick glow plugs
different injectors (same as l400)
different cylinder head
after oil I don't think you can expect anything different from a '95 to a '94
after oil
Re: 1995 L300
Post by after oil »
the intention of the purchase is to sell it. im a little worried that i might want to keep it.. dont tell my space antelope....
Re: 1995 L300
Post by Green1 »
impalator wrote:Does anybody have any idea as to the advantages of a watercooled turbo vs. a non-watercooled or oilcooled turbo? Won't it be running as hot?
doesn't run as hot, cools down quicker, generally just a "good thing" (TM)
Erebus
Vehicle: 1992 Super Exceed
Re: 1995 L300
Post by Erebus »
Let's clarify. It is water-cooled AND oil-cooled, not instead of. The older pre-94 were only oil-cooled. Helps it run cooler, and, depending on the design, might thermo-syphon after engine stop to continue cooling, making it less critical to idle the engine for a cool-down cycle when stopping.
