lift kits
Ramsvan
Vehicle: Delica L400
lift kits
Post by Ramsvan »
Hello I am wondering where to get a 4 to 6 inch lift lit for a L400?
Mr. Flibble
Re: lift kits
Post by Mr. Flibble »
I believe jfarsing who posts on this forum makes them. If you do a search you can find his posting about how to know if you have a good lift kit.
Welcome to the forum.
Re: lift kits
I only have 2-2.5" lift kits.
If you are looking for a 4-6" suspension lift, you will have to enquire over in Japan or Taiwan.
The last time I checked it was approx. $3,900 canadian + shipping.
This included :
4 shocks
front subframe spacers
upper balljoint spacers
extended steering shaft
coil spring spacers
coil spring retainers
sway bar drop down brackets
brake booster relocating spacer
drop boxes for lower control arms (welding required at the frame)
upper and lower adjustable extended control arms
extended brake lines
yoke extension for driveshafts
It was a pretty substantial kit and shipping was over $1,200.
The cost of the kit plus shipping was too outrageous to even consider.
