L400 Oil filter and service USA?
Posted: Mon Jun 21, 2010 10:18 pm
by Movendi
Hi.. i'm in the middle of my road trip and i'm 6000km since last oil change so i desperately need one before i continue. I'm in San Diego and from what i understand i need to get an oil filter as well. I been searching all over google and delica.ca and can only find that a Fram ph9055 will fit which i was reading is a really bad oil filter.. So I really need to get moving and i can't even find the FRAM in a brick and mortar store. So im not sure whether to import one from canada which will cost way too much or try something else? There's little info on this so i think if i do eventually find this fram model it'll make things worse cause theres far too many complaints about it leaking and busting up.
I have a 94 l400 4m40 pe8w
Any ideas? Maxoverdrive says they're out of parts and now im really clueless =\
Re: L400 Oil filter and service USA?
Posted: Tue Jun 22, 2010 9:29 am
by graymouser
Movendi wrote:Hi.. i'm in the middle of my road trip and i'm 6000km since last oil change so i desperately need one before i continue. I'm in San Diego and from what i understand i need to get an oil filter as well. I been searching all over google and delica.ca and can only find that a Fram ph9055 will fit which i was reading is a really bad oil filter.. So I really need to get moving and i can't even find the FRAM in a brick and mortar store. So im not sure whether to import one from canada which will cost way too much or try something else? There's little info on this so i think if i do eventually find this fram model it'll make things worse cause theres far too many complaints about it leaking and busting up.
Does the NAPA Gold filter 1675 fit (or the NAPA Gold 1809, which I believe is just longer)? I think it crosses over from a PH9055 and should be readily available in the States (and in my opinion NAPA has better filters).
Hope that helps.
Posted: Fri Jun 25, 2010 9:12 am
by MardyDelica
hi, go to any fuso truck part & service dept
you can buy there in there parts dept;
same as your L400 4m40
part number # ME088532
hope this help you
cheers;
