Gear set source ?
- Vehicle: 1991 Pajero
Gear set source ?
Has anyone found a Ring and Pinion supplier for the gen 2 pajero ? I would like to re gear my diff's..
1991 Pajero. 5 speed, 2.5L intercooled.
33" kuhmo tires on black steelies
- Vehicle: exceed
Re: Gear set source ?
Try "Randys' Ring and Pinion" in Bellingham Washington, they have a websight that has good info regarding ratio options and availability.
- Vehicle: exceed
Here's the link - http://www.ringpinion.com/
Should have added it to the earlier post.
I have talked to them already.. They have nothing.
I really need to find a way to lower my highway RPM.
Larger tires.. I have 33's, so a bit of lift and 35's would drop me by about 300 rpm.
Re gear. If i could find a different ratio ( like a 4.56 or so ) that would drop me to about 2K @ 100 kph.
Different 5th gear ratio ?
