Has anyone installed the round Madman gauge? I'm looking to put it in the dual gauge pod in place of the inclinometre. Not sure if it will fit or even how the pod comes apart. Another way might be to put a clamp around it and bolt it to the dash, but it probably wouldn't look as good.
I've removed the pod and realize I need a replacement one as the base is cracked and totally destroyed where the dash mounting screws go. Anyone have a dual one they'd like to part with?
I plan to connect EGT and Boost. The Madman also came with 2 temperature sensors. Any thoughts on the 2 best temps to monitor?
Madman Gauge Install
- danfromvan
- Vehicle: '93 p25w Jasper auto
Re: Madman Gauge Install
Look at this thread for my EGT install. I took the gauge apart on the dash of my Pajero (very similar). I used a Dremel tool to make the facia and the other openings just that little bit bigger.danfromvan wrote:Has anyone installed the round Madman gauge? I'm looking to put it in the dual gauge pod in place of the inclinometre. Not sure if it will fit or even how the pod comes apart. Another way might be to put a clamp around it and bolt it to the dash, but it probably wouldn't look as good.
