where is the door ajar switch on the rear door(tailgate)
maxpowers
Post by maxpowers »
ive got the door symbol on the dash on and the small light at the sliding door on. any ideas?
session the gnar
Re: where is the door ajar switch on the rear door(tailgate)
The light beside the sliding door is switched (unless you've got a different one).
The switch for the rear gate is inside the latch. Better latching turns out the light on your dash. Cleaning of the latch provides for better latching.
maxpowers
Post by maxpowers »
you can turn the light in the floor the one on the step up, on and off with a switch?.
in side the door latch hey, that explains it. it is really sticky on my deli, anyone got any easy ways to get in there. its so sticky i can barely work it with a key.
session the gnar
maxpowers wrote:you can turn the light in the floor the one on the step up, on and off with a switch?.
Okay, now I'm confused because it sounds like you're talking about two different doors and different lights.
Side door, when opened will turn on the indicator on the dash and the overhead lights (if the switch is set). There is another light, down in the foot well or step, that usually has a switch right beside it. I don't know if that one comes on when the door is opened. I don't remember where the switch for the door is.
Rear door, when opened will turn on the indicator on the dash and the overhead lights (if the switch is set). The 'switch' for the rear door is inside the latch at the bottom of the door. If the door doesn't latch correctly, the dash indicator may flicker.
This would be much easier if I still had a Delica, so maybe one of the others can chime in, with pictures.
As for your sticky lock, WD40 or LPS will do - spray it right in where the key goes.
maxpowers
Post by maxpowers »
thanks,
but what is the function of the vent thing in the tailgate? can i tape it up so it stops letting dust in?
session the gnar
maxpowers
Post by maxpowers »
no same step light, mine does'nt have a switch? it just comes on when you open the tailgate or slider.
and thanks, that explains the door ajar light, mine is seriously jammed with dust.
I will have at it with Wd, I just wasn't sure if there was a switch i wasn't seeing somewhere on the tailgate.
thanks a bunch!
session the gnar
maxpowers wrote:thanks,
You could, but it helps with air flow through and out of the vehicle. Unfortunately, it also allows dust into the vehicle when travelling down dusty roads.
Erebus
Vehicle: 1992 Super Exceed
Post by Erebus »
maxpowers wrote:but what is the function of the vent thing in the tailgate? can i tape it up so it stops letting dust in?
It's to let air out. If driving on dusty roads, have the front ventilation fan running to "pressurize" the Delica to keep dust from coming in the back.
