Glow plug test
Posted: Sun Sep 05, 2010 1:57 pm
I replaced the Injection Pump Seal.
Now I am ready to go, but no luck in starting.
See thread
http://www.delica.ca/forum/rough-start- ... -8806.html
I thought I would recheck everything just to eliminate my doubts.
Started with glow plugs. Tested to see if there was power cycled to the glow plugs at the turn of the key. Yes 12v until the 'click' sound at 10 seconds then nothing. Seems normal.
Took out the plugs one at a time.
Connected Ohm meter red lead to post, black lead to threaded end that sits in the block.
Ohm meter shows resistance on all but one.
Went a step further and hooked up the jumper cables to the battery and then to the loose glow plugs. Red on threaded end that sits in the block, black to post. Wait ten seconds. Disconnect. No heat. When I say no heat I mean cold as the concrete floor.
All were cold with no change, except one which became warm like if you feel the top of your computer monitor but by no means was there any "glow" to the plug.
Could this be the root of my problem?
The ends of the plugs looked a little swollen, pitted and rough.
I welcome your thoughts.
Mike
See thread
Mike
