Stereo Wiring Harness
Jordan
Vehicle: 89 low roof L300
Post by Jordan »
I am working on Stereo 2.0 after my first one was stolen and noticed a couple discrepancies in the wiring diagram and wanted to double check.
I have been going off of this:
http://www.grannyspit.com/delica/stereo_connectors.htm
Everything on the wiring harness matches up except for:
Left rear + and Left rear - are switched
and
Right rear + and Right rear - are also switched.
is the diagram correct or is the wiring harness correct?
White Mule
Vehicle: 1991 Delica L300
Re: Stereo Wiring Harness
Post by White Mule »
Not sure if this will help, but try "+dodge colt harness" on the search tab.
Good info there.
White Mule
Jordan wrote:I am working on Stereo 2.0 after my first one was stolen and noticed a couple discrepancies in the wiring diagram and wanted to double check.
and
If you know the lines are switched, then use them as they work.
There are two things to take note of: Mitsubishi doesn't use the North American wire colour-code convention; and after 20 years white might look like grey (or vice versa).
Super Exceeded
Vehicle: 1993 L300S
Post by Super Exceeded »
I just rewired my stereo and found the same issues. I simple tested every lead until they worked in the speaker I wanted. You may have to do the same. Whether the speaker or the wire harness itself, I have found a lot of time the colours really don't mean much.
yojimbo
Post by yojimbo »
I just got a delica to iso harness.
1994 L300 Jasper
1986 Scimitar 1.8Ti
Jordan
Post by Jordan »
I traced the wires and in this circumstance the wiring harness was correct. The 2 rear speakers polarity was reversed on the online digram i was going off.
TardisDeli
Post by TardisDeli »
Jay of the TardisDeli posted the wiring colour code and functions here
http://www.delica.ca/forum/radio-wiring ... tml#p27824
Hope that helps. Christine.
Christine
