REAR SUSPENSION
SCOTT905
Vehicle: 1994 L400 DELICA
REAR SUSPENSION
Post by SCOTT905 »
WHEN PULLING MY CARGO TRAILER THE REAR SUSPENSION SAGS.NEED TO ADD AIRBAGS OR COILS WHAT IS THERE OUT THERE TO SOLVE THIS PROBLEM....THANKS.
Re: REAR SUSPENSION
SCOTT905 wrote:WHEN PULLING MY CARGO TRAILER THE REAR SUSPENSION SAGS.NEED TO ADD AIRBAGS OR COILS WHAT IS THERE OUT THERE TO SOLVE THIS PROBLEM....THANKS.
SCOTT905 wrote:WHAT IS THERE OUT THERE TO SOLVE THIS PROBLEM
SCOTT905 wrote:ADD AIRBAGS
YOU ARE WELCOME !
Mr. Flibble
Re: REAR SUSPENSION
Post by Mr. Flibble »
YOU COULD ADD STRONGER COILS, BUT AIRBAGS ARE MORE VERSATILE!
Re: REAR SUSPENSION
AIRBAGS ARE BETTER FoR ToWiNg aS yOu GeT tHe NoRmAl RiDe HeIgHt wItHoUt tHe TrAiLeR aNd AdDeD lIfT wItH AiRbAgS WhIlE ToWiNg.
SoMeThInG's wRoNg WiTh My CaPs LoCk. :-D
Re: REAR SUSPENSION
WHY ARE WE YELLING?
unclebazwold
Vehicle: Delica L400
Re: REAR SUSPENSION
Post by unclebazwold »
What is the nose weight of the trailer the springs may also just be sagging with age and a pair of ironman springs may solve the problem.
Bazza
mrdueck
Vehicle: '95 L400 Super Exceed LWB
Re: REAR SUSPENSION
Post by mrdueck »
I've got the same issue. I suspect the coils are tired but I don't want to put HD springs in and loose my comfort ride. We travel Wpg to BC ALOT. Airbags is what I am starting to seriously consider. I'm not crazy about how the Firestone slip in the coil plastic looking ones as they don't look very durable and am considering finding some more "truck" type rubber ones. Problem at this point is finding the right one to mod for the L400. I plan to do this for the summer vacation. Has anybody else looked into this?
tonydca
Re: REAR SUSPENSION
Post by tonydca »
I've sorta got the oppostie complaint. I think the standard-issue L400 has a fair amount of unsprung weight, so it's pretty choppy over little bumps around town.
The best ride quality I ever had was when I was hauling about 600 lbs of turf stacked up over the rear wheels. Smoooth!
So yeah - air bags'd be a neat upgrade.
ealanm
Vehicle: '95 L400
Re: REAR SUSPENSION
Post by ealanm »
Is it possible you're just got more tongue weight than you should have? Unless it's a really big trailer, if one reasonably strong person can't lift the tongue off the hitch there's probably too much load on it.
"The trouble with quotes on the internet is that it's difficult to determine whether they've been correctly attributed."
-- Abraham Lincoln
mrdueck
Re: REAR SUSPENSION
Post by mrdueck »
3 kids, a dog, a full rack on top and she is saggying. I haven't even got a hitch on her yet.
Re: REAR SUSPENSION
ealanm wrote:Is it possible you're just got more tongue weight than you should have? Unless it's a really big trailer, if one reasonably strong person can't lift the tongue off the hitch there's probably too much load on it.
Tongue weight is generally not supposed to exceed 10% of total trailer weight.
