Outer tie rod ends
JazzyBC
Vehicle: Delica
Outer tie rod ends
Post by JazzyBC »
Hey all,
So part numbers are a *itch at times aren't they? I've tried searching on here, but not having much luck. Any one know the numbers for the outer tie rod ends? Help appreciated!
Thanks,
Erika & Jazzy Miss Bitchy
Dino
Vehicle: 1994 Pajero 2800 LWB
Re: Outer tie rod ends
Post by Dino »
I've got two MOOG numbers for a '94 Montero 3.5L, just do a Google image search for them and see if they match what's on your van.
ES3386RL
ES3387RL
The second one has a slight curve to it and IIRC that's the one my V46 has.
Hi Erika,
Go to the Delica FAQ Section in Delica Canada Technical; click on "Useful Links for Vehicle Part Identification Purposes."; scroll down to "JDM Online Catalogue" and click on that; enter your VIN (Vehicle Identification Number) into the Mitsubishi Field and click enter. This should produce every stock OEM parts number for your Delica as she rolled off the assembly line in Japan (including her birth date) :-) .
P.S.: If you have the OEM number then it can be cross referenced.
JazzyBC
Vehicle: Delica
Post by JazzyBC »
I had found some MOOG #'s but they were not a fit, so mucked that up some how, or the info. I had wasn't accurate...
Falco - I tried that as well, but Lordco said they couldn't cross the numbers I had... I'm getting the feeling I'm screwing something up here... ;)
Erika
Really? Where are you located? The Lordcos that I go to have put together an extensive list of Delica parts, originally started up by a Lordco in the Victoria area. Although I understand that the Space Gear list is not as populated. All the same, the parts numbers should start with MB or MD, i.e.; Starwagon stop light switch (MB113078), Starwagon glow plugs (MD092392), Starwagon tie rod end assembly (MB527650) &c.. They should be able to cross reference any OEM number in the world.
You can consider going to some of the garages that specialize in Delicas (depending where you are), or ~ check out Rocky Mountain Imports.
JazzyBC
Vehicle: Delica
Post by JazzyBC »
I'm in little ol' Lillooet...
I'll go in and bug the guys again tomorrow and tell them that "at other Lordco's..." Could be they are pulling the "don't want to deal with the chick" thing... ;) Fellow I spoke to looked in his book and that was the extent of it. Said "sorry, those don't work".
I'm persistent, I'll get it sorted! Or they'll never get rid of me... :)
Rising Sun did have the courtesy of getting a message to me very promptly with a price quote, I'll check around to see what others can do as well.
Thanks again Falco
JazzyBC
Vehicle: Delica
Post by JazzyBC »
Looking at the numbers you posted, I did have the right ones, it's them not me... (She says as she flashes a cocky grin...)
Erika
Return to “L400 Technical”
