WTB EGR blanking plate
sfd_656
Vehicle: l400
Post by sfd_656 »
Who is selling them? prefer in BC.
Firesong
Post by Firesong »
You can check with rising sun. I know they fitted mine with one when I bought the van.
Yokohama
Re: WTB EGR blanking plate
Post by Yokohama »
sfd_656
Vehicle: l400
Post by sfd_656 »
that seems like a good resource i will look further into it thx.
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
Yokohama wrote:Why you should KEEP the EGR ON A GAS MOTOR:
http://www.tuneruniversity.com/blog/201 ... you-money/
Fixed that for you.... article is about gas engines not diesels...
Yokohama
Post by Yokohama »
Yes, thank you! That would only apply if the OP has a gas motor.
If you don't want the EGR you don't need to put in a blank - simply disconnect the vacuum hose that hose that engages it.
konadog wrote:If you don't want the EGR you don't need to put in a blank - simply disconnect the vacuum hose that hose that engages it.
As an addition to Konadog's observation ~ put a machine screw into the end of the vacuum hose when you take it off.
TieMyShoe
Vehicle: L300
Post by TieMyShoe »
Frost plug fits perfectly inside the EGR as well.
