Daytime running lights
David
Post by David »
Thought these would be easy. Went to Canadian tire $25.00. Do not use with Mitsubishi stamped right on the front. Grrr. Napa says theirs is exactly the same in a different box (doesn't say no Mitsubishi) $99.00. When I told him the price at Can Tire he said he could let it go for $56.00. Not convinced I should try it though.
Anyone with first hand knowledge?
David
1991 Delica Exceed
mark
Member's Photo Album: http://www.delica.ca/Photos
Vehicle: 1994 L400
Post by mark »
I installed the Canadian Tire ones that said "Do Not Use with Mitsubishi." There was no problem with the installation or functioning. :D
David
Post by David »
Hi Mark
Is your delica a diesel?
I was told those modules require a feed from a sparkplug wire for juice and so won't work with a diesel.
1991 Delica Exceed
Breadman
Post by Breadman »
david, if you still need that place to get the vehicle passed let me know as my friend here on the island just did it in nanaimo, no running lights or modifications what so ever. the mechanic just checked the brakes, muffler, etc. like with both of mine and passed them.
paul
mark
Vehicle: 1994 L400
Post by mark »
My (former) delica is a diesel -- the $25 Canadian Tire DRL kit can install to either a gasoline or diesel.
There is a one-page instruction sheet that comes with the DRL kit which explains the installation on either gas or diesel. In the case of a gasoline vehicle, the feed wire connects to the sparkplug. In the case of a diesel the feed wire connects to the oil pressure switch.
digitalart
napa DRL kit
Post by digitalart »
I came across the same thing today. I have a 91 Deli I drove bought from a guy in Calgary, but I need to get the DRL installed. Can. Tire's version does say not for Mitsubishi, so I went to Napa looking for filters ($29 minimum) and a DRL kit. $80 plus taxes.
The kits says "not for use in vehicles with the headlight switch on the ground side of the circuit", and they don't specify gas or diesel feed locations.
I'm taking this back and getting the Can. Tire version today!
ccautos
Vehicle: 92 Delica SE
Post by ccautos »
Grote produces a universal DRL unit that is a simple three wire installation and uses the low beam headlamps . Also can be used on gas or diesel . Can be found at any Lordco / Napa store . We can install daytime running lights on any Delica for $60 plus parts. Also we can install illuminated side marker/reflector lamps to meet DOT regulations. http://www.coombscountryautos.com
digitalart
DRL kit not required
Got my VIN plate installed, inspected and insured - finally!! The VIN plate only took two days from Vancouver - miracles do happen.
I asked my inspector/mechanic to install the DRL kit, which ended up not being necessary. He made some connections to the fusebox, soldered, fused correctly, so when the key is in the on position, the headlights come on. 1/2 hour job, $5 for parts. It works well.
I was required to install a high-mount brake light... got the 12" LED version for about $95, plus installation (1.4 hours).
39Ronin
Vehicle: Mercedes Benz Gelandewagen 300GD
Post by 39Ronin »
mark wrote:I installed the Canadian Tire ones that said "Do Not Use with Mitsubishi." There was no problem with the installation or functioning. :D
Where is the oil pressure sensor found that I should connect to? I didn't see it near the block or oil filter. :?
argo
Post by argo »
Where abouts are you guys splicing into the low beam wire ?
argo
Post by argo »
Anybody ?
ccautos
DRL`s
Post by ccautos »
We connect in right behind the steering column on the headlamp switch wiring coming down the column .
argo
Post by argo »
Many thanks
Shepherd
Post by Shepherd »
Went back and re read these postings. I have instaled the Canadian tire kit. I am almost finished. Where is the oil presure switch or other posible location for this wire to atach to? what did you do?
Delicaman
Vehicle: 1992 Super Exceed
Where is the Oil Pressure sender? Got Pics?
Post by Delicaman »
I have a 91 Delica super exceed and am doing the DRL install.
Where did you guys install the DRL unit? Where did you get the Power feed? Direct from the Battery as stated?
Cheers all,
Benn :o
