Temperature gauge wiring??
oceaneer77
Vehicle: 91 exceed, 87 porshe 928, 67 datsun
Post by oceaneer77 »
Ok after all of the discussions on the temp gauge... I started to look into mine.. :o
ours never reads above the 1/10 th mark so i wanted to check the gauge and wiring.
I see that the head has 2 probes in it.. one is 2 wire an done is single wire.
I would imagine that the 2 wire one is a temp probe and the singe one is a temp switch/ alarm..
is this correct.
At any rate the 2 wire one has voltage on it but the single has nothing.
Our truck at idle has reaches only 155 F so the thermostat is opening much to soon.
are my assumptions correct?
Dylan H
Re: Temperature gauge wiring??
Post by Green1 »
oceaneer77
ok one more thing.. i broke the temp sensor when removing the very hard plastic boot..
Does any one have a number for a lordco one??
thanks
Dylan
Post by Green1 »
I don't have a part number, but I can recommend talking to coombs country autos or rocky mountain imports, either of them can probably help you out.
Kevin
Vehicle: 92 Exceed
Post by Kevin »
I believe the single wire sensor disables the air conditioning compressor clutch if the engine temp gets too high.
