Nomis wrote:Green 1:
It's interesting that you noted the L400 has more ground clearance, I thought the L300 for sure did.
At least as stock goes. I know mods can change that.
please clarify. thanks.
It's difficult for me to be definitive on this one. My L400 definitely has more ground clearance than my L300 did, however my L300 was also low because of worn suspension and smaller than stock tires. However my understanding is that the stock L400 is slightly higher than the stock L300 (though as mentioned earlier, either one can be lifted if need be)
Also do you find the breaking system any better on the L400's?
I don't like the slow heavy break of the L300's so much.
I find the braking feels much stronger on the L400, on the L300 I felt like my foot had to do more of the work, whereas on the L400 it feels like the power braking works better. That said, I doubt my stopping distance is actually much better, simply because my L400 is a heavier vehicle, I just don't need to stand up on the brake pedal to make it happen. My L400 also has the ABS system, and while I'm generally not a fan of these systems, the one in the L400 is much less obnoxious than the ABS systems I've used in GM and Ford vehicles. (in both the Ford and GM there was always a very noticeable loss of stopping power when the ABS kicks in, this is not nearly as evident on the L400)
The L400 is much more "powerful" in every respect, it is easier and more comfortable to drive, that said, the L300 seemed to me like it was better thought out, little details just seemed better put together in the L300, the L400 feels more like most modern vehicles where the designers weren't actually thinking they'd be the ones using the vehicle. I'm not sure if I managed to convey what I mean here... so here's a simple example: The L400 rear bench folds flat, but they didn't think to make it have a latch point at flat, only at about 30 degrees up, and 30 degrees down... neither one is so comfortable for sleeping on. The captains chairs swivel, but not 360 degrees, only 270, this means you can face almost any way you want, but you often have to rotate the wrong way to get there.
Every feature I touched in the L300 just felt very well thought out, if I wanted something it was usually exactly where, and how, I wanted it. In the L400, despite having far more options (or "toys") they feel more "tossed in" and like not as much thought was put in to the process (time crunch in the design department?) Don't get me wrong, I love my L400, and don't for a moment regret going that route, I believe it truly is turning out to be better for my particular purpose than the L300 was, but it is not as simple as saying that one is better than the other for any one person or application, it is a very personal decision with a lot of variables to consider.
