FalcoColumbarius wrote:None of them have a choke, no carburettor.
I believe from the '93 on the engine has an automatic throttle adjust that compensates for a cold engine.
As far as glow plugs go ~ what do you mean by "normal"?
jfarsang wrote:the advantage for the water cooled turbo (93+) models is it runs cooler than the oil cooled (pre 93) models
cooler turbo = better when climbing hills
Sorry hand throttle old tech! similar to the old 1.6 vw diesel or series Landrover good thing to have specialy in a 4x4 whats up with all the clicking don't you just turn the key either count to 15 or wait for the light to go out then start? my expreience with car diesels is limited to vw and landrover 2.5 n/a turn key pray light comes on count to 15 then start or the 87 Range rover (2.4 VM diesel) turn key wait till light goes out Auto timer then start.does the 93/94 have the automatic system?
which turbo set up is better? and are there other detail differeces betwwen 91 and 94 models?
Maybe should have posted in general discussion but other potential deli buyers will have similiar technical questions! thanx
