what montero/l400 parts are the same?
Dunc
Vehicle: L400
Post by Dunc »
Is there a list of parts the L4oo share with the montero? I know i've seen parital lists somewhere.Specifically i'm looking for a Radiator. Front montero calipers from napa belingham are less than half 70$ what Japanoid is asking.Thanks dp
MEXIBISHI
Vehicle: 1994 Mitsubishi Delica Space gear
Re: what montero/l400 parts are the same?
Post by MEXIBISHI »
Rear and front brakes asembly, and some components from the front end.
By the way, if you can't find a brand new radiator, you still can fix it, depending where is the leak located.
(On the plastic or the aluminum part) You can message me if you want more info.
Same :
Rear brake rotors, calipers and pads
Front brake calipers and pads (rotors are different)
Return to “L400 Technical”
