FS Delica High Roof Crystal
mdrive
Post by mdrive »
Price: 10,750.00
BC Inspection Complete. (New Tires, Headlight, DRL, Front Corner Light Added, HIgh Mount Brake Light)
Servicing Included in the price with 1 year Power Train Warranty:
Clean Battery Terminal
Brake Pad Replace (if below 40%)
Rotors Machined
Front Wheel Bearing / HUB Re-Grease
Ball Joint (Check / Replace)
Tie Rods / Steering Link (Check / Replace)
Sway Bar Bushing Replace
All Suspension Parts Regressed.
Shock Absorber Inspection (Check / Replace)
Coolant Flush (Radiator Rebuild if Necessary)
Engine Flush
Oil Chevron Delo 400
Power Steering Fluid Flush
Clutch Fluid Flush
Brake Fluid Flush
Gear Oil Chevron
Differential Oil Chevron
Transmission Fluid Chevron
Thermostat (Check/Replace)
Water pump (Check/Replace)
Radiator Cap (Check /Replace)
Power Steering Belt
Alternator Belt
AC Belt
Air Filter Change
Fuel Filter Change
Oil Filter Change
Change Muffler or Pipes when needed.
New Wipers Installed
All Hinges Greased
Complete Detailing Package (Interior, Exterior, Enigne)
