Larger tires wrecking inside of sliding door
macro
Vehicle: L400 "The Invader"
Post by macro »
As the title says, my 31" Duratracs have almost completely wrecked the inside of the slider. It was fine for months but then one corner must have caught and slowly peeled itself back, so now the door only slides open about two feet or less.
So, just wondering if anyone has had the same problem and what the solution was? I'm assuming that I'll just have to remove the lower half of the panel and replace it with.... I'm not sure what. Hopefully something half decent!
fredt
Vehicle: l400
Re: Larger tires wrecking inside of sliding door
Post by fredt »
http://www.mdocuk.co.uk/forums/viewtopic.php?t=40544 a diy hinge extender! there is a post somewhere with the specs for making a proper one
macro
Post by macro »
Awesome, thanks! I didn't realize there was a DIY option! I've only seen the machined ones. I notice he had home made fender flares too.... Hmmmmmm.....
Jordan
Vehicle: 89 low roof L300
Post by Jordan »
If its just rubbing the door skin you could peel back the vinyl cover, cut out a notch in the masonite where it rubs and staple the vinyl back.
You could also use duct tape, eh? More or less the same colour as the grey lining.
macro
Post by macro »
It's actually pulling the panel off and peeling it back, so I think some cut'n will have to take place. But not until spring decides to show up out here.
