Does your L400 have these?
stever1000
Vehicle: 94 L400 SuperExceed
Post by stever1000 »
I noticed my L400 has two empty spots where the idle adjustment switch and air flap switch are in these two pictures:
Throttle/idle switch
Air flap
(images borrowed from: http://www.delica.ca/forum/now-that-i-h ... 15188.html
Does your L400 have either one of these? Do you use them?
I don't care about the air flap, but I would like an idle adjustment switch for cold mornings until the engine warms up. Can I simply find a switch and install it, or would my delica lack all the necessary components?
Thanks!
simsim
Vehicle: L400 Series 2
Re: Does your L400 have these?
Post by simsim »
Have both, don't really use them. My L400 2nd Gen doesn't really need the choke. Albeit this winter hasn't really been that cold so I haven't had much use for it...
As for the air flap, no, not really... I don't really see much point in playing with it much as it doesn't make too much of a difference open or closed..
Big-Bird
Vehicle: 96 PE8W Spacegear
Post by Big-Bird »
The vent control is usefull on really hot days when you want more air flowing through the cab area. Works best when the back side windows are open.
The throttle control is a cable controller that is directly connected to the accerator pedal linkage. Its a manual control that you pull out to set RPM's and turn 1/4 way to lock/unlock. Good for cold winter mornings when you want the RPM to hover around 1000. Its not a choke control which would be on a carb'd engine which the L400 doesn't typically have. They had the 2.4 EFI, the 3.0 EFI, the 2.5 TD and the 2.8 TD Intercooled.
There might be a way to install a switch to set the idle speed but that means translating the wiring schematic at the Mechanical Injector Pump on the Gen 1 L400 or the Electronic unit found on the Gen II.
stever1000
Do all L400's have the air flaps installed, but only some have the switch to open?
I've contacted Graham at CC about the manual throttle
Thanks!
Big-Bird
Post by Big-Bird »
Availability of these 2 controls seems to vary between the various trim levels. Some have a throllte control and no vent control (like mine).
Some have neither.
But if you start your deli and set the manual throttle you will know if its connected or not. The cable from the manual pull attaches to the top of the accelerator pedal. Easy to see from the floor area...not so easy to reach.
patriceboivin
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=23122
Vehicle: Mitsubishi Delica L400 Super Exceed
Post by patriceboivin »
mine doesn't have either, I was wondering what was supposed to be there.
stever1000
Big-Bird wrote:Availability of these 2 controls seems to vary between the various trim levels. Some have a throllte control and no vent control (like mine).
Some have neither.
Yeah I can see where it is attached now. Too bad mine doesn't have one, I think it would be handy for cold mornings
Mr. Flibble
Post by Mr. Flibble »
Mine has neither of these. I would really like the throttle cable and will probably order one.
What exactly does the vent one do? Would it even work on the system that is installed for a Royal Exceed?
volnoir
Vehicle: 95 L400 Super Exceed
Post by volnoir »
I have the choke in my l400, and use it like others have said, on those cold mornings to help warm up the engine.
Firesong
Post by Firesong »
The vent control is more simple than you think. It closes the intake and opens it. I can't honestly see a reason for it since you can choose to recirculate air from the other control. It literally shuts a flap.
Mr. Flibble
Firesong wrote:The vent control is more simple than you think. It closes the intake and opens it. I can't honestly see a reason for it since you can choose to recirculate air from the other control. It literally shuts a flap.
So, it does exactly what a button on my dash already does then.
Firesong
Post by Firesong »
Yup. I see no point to it. It literally moves a flap down to block the intake of air behind the cabin filter intake. Here's a picture my finger is pointing to the mechanism that is activated [img]http://tapatalk.imageshack.com/v2/15/03 ... 72f71f.jpg[/img]
Firesong
Post by Firesong »
It does not 'literally' do the same mechanical function. But it redundantly does the same function.
Big-Bird
Post by Big-Bird »
ROFL.....(funny stuff Firesong)
