I could be mistaken on this, my info on this was gathered from a well respected Delica mechanic from across the pond, who I conversed with quite often before I brought my first L400 over in the summer of '09. I was told the lifter was a hydraulic type, and the shim was a sacrificial surface designed to wear before the cam or lifter. I will have to pull a lifter out of one of my core engines and see if it has any oil holes, making it a hydraulic type. The highest mileage ones I see out here, are mine with just over 220km, and my wife's white one we sold in march of '12, which I think also had around 220km when we let it go, but I believe it is still starting and running well, aside from a block heater cord issue last winter. If I'm wrong I apologize, I will, report back once I physically remove one of the here and check.
Jason
X2 its a wear surface as far as i know.
						Injectors
				403delica
 - Vehicle: LWB L400
				403delica
 - Vehicle: LWB L400
Re: Injectors
totally should have read the whole post
				djelica
 - Vehicle: L400 Super Exceed
Re: Injectors
Thanks everyone for your input.
So they can be adjusted. Anyone know what Mitsubishi recommends for servicing? Again I just want to do the right thing and have my L400 run as long as possible.
Cheers, Darren
Cheers, Darren
				davidwwc
 - Vehicle: 1994L400 Delica
Re: Injectors
Hi Guys,
Just wondering how hard is it to adjust the cam with shims on the L400?
DC
DC
				Diver
 - Vehicle: L400
Re: Injectors
It's a bit of a faff, but not hard. Firstly measure to see if they need adjusting as I described above. Chances are they won't. It's pretty rare for them to need any attention after initial setting up but possible if it's a high mileage vehicle with the original head or if oil changes have been neglected.
I don't know if Mitsubishi have a recommended time-scale for checking but it's simple enough so worth a look whenever the rocker cover is off. Maybe combine the job with replacing leaky half-moon seals or making sure the breather baffle in the top of the rocker cover isn't becoming blocked.....
