Hello,
I just purchased a L400 and need to replace these parts:
Rear stabilizer joints
Trailing arm bushings
How/where can I source these parts? Can I replace them myself? I looked in the L400 manual PDF and can't find the specific parts
Any help would be greatly appreciated
Rear end parts L400
- Vehicle: 94 L400 SuperExceed
- Vehicle: 1995 l400 swb
Re: Rear end parts L400
Get you parts threw Rocky Mountain imports http://www.rockymountainimports.net/
Had mine done at a shop. .
- MardyDelica
well buzz me in I have all those parts in stock and can installed it easy
cheers
cheers
If I buy the parts can I replace them myself, or do they require special tools?
- MardyDelica
hi, u need a special tools to take it out from one is the hardest one need to do alignment
cheers
cheers
- macro
- Vehicle: L400 "The Invader"
Sway bar links are easy DIY, trailing arm bushings need a press from what I know.
-Mat
@delicacanada on Instagram
Thanks, that is very helpful!macro wrote:Sway bar links are easy DIY, trailing arm bushings need a press from what I know.
