Are shades under tension when closed or when opened?
snelson
Vehicle: 92 Delica Exceed
Post by snelson »
Quick one here for those that know the innards of the crystal light shades.
All four of mine are still working, and I'd like to keep it that way. So, what's better - to leave them opened or closed as far as tension on the shades/clips/sliders etc...? I've been leaving them closed for most of the summer.
Steve
The Pinkfingers
Vehicle: '94 Exceed
Re: Are shades under tension when closed or when opened?
Post by The Pinkfingers »
I never thought of that before. I would have thought either is the same tension, and the tension occurs when they are opening or closing. So I've been opening / closing them as little as possible.
But I'm interested in hearing the reply from someone who has actually taken them apart and fixed them - they would know.
docsavage
Vehicle: Deliless...
Post by docsavage »
They are under tension when closed. With no clips they snap back to open position.
James
James
1989 Delica P24W Exceed
Panasonic CQ-TX5500W
snelson
Post by snelson »
In-tah-resting....thank you sir. :-)
steve
docsavage wrote:They are under tension when closed. With no clips they snap back to open position.
James
Not sure about that because the push/pull mechanism is a braided cable on a spool: spool spins one way and pushes the blind out; spool spins the other and pulls the blind in. I don't think there is any 'tension' in the system.
docsavage
Post by docsavage »
My clips were broken in a couple shades, they always snapped back (much like those roll up blinds in school) to the open position unless tied shut.
James
Post by Green1 »
