Delica E-Code Headlight ( DEPO)
- MardyDelica
Hi, Now offering Delica E-code headlight DEPO Brand:
for $270 + Tax a pair with 4 Brand new bulb included Made in Germany
This New headlight has a European City Driving light attach on it.
Few stock available now pls call 604-720-6144 or e-mail me
Thanks,
Thanks,
- sasquatch-hunter
- Vehicle: 2 Delica
Re: Delica E-Code Headlight ( DEPO)
Hi Mardy,
Can I use the small bulb as DRL? Are they bright enough?
cheers,
seb
cheers,
seb
- MardyDelica
Hi, sorry sebastian,
they are not bright enough to pass inspection compliance.
they are only used in asia & europe, as per our rule here is different.
sorry it will be nice.but cannot do anything for the compliance.
cheers;
cheers;
- Pajerist
Hi, Mardy!MardyDelica wrote:Hi, Now offering Delica E-code headlight DEPO Brand
What about headlights for 1994 Delica Spacegear? I am ready to buy.
Thanks!
- MardyDelica
hi, for spacegear no e-code headlight available. even its for left hand drive country.
for now thats a big problem. nobody have it even depo dont have it.
will see if i can came up soon. for now i think convertion is the only way
cheers;
cheers;
- Pajerist
oups!
what kind conversion do you have in mind?
thanks!
thanks!
- MardyDelica
Hi, sorry,
i dont know yet need little bit concertration.
not easy.
cheers;
mardy
not easy.
cheers;
mardy
- Erebus
- Vehicle: 1992 Super Exceed
Ages ago, Mystery Machine posted how to convert the L300 headlights from RHD to LHD. Not sure if it was on here or the UK forum, and I'm feeling too lazy to search. It was quite the interesing thread. I suspect that the same technique would work on the L400s.
- Pajerist
There is no sense to convert RHD to LHD headlights from UK, because they E-coded for RHD cars.
so with such E-code (do not recall exact#) it will not pass OOP.
Good luck,
Good luck,
- Erebus
He did it just to see what it would involve. The problem with the conversion is that the glass still indicates RHD, and the inspectors don't look at what the light pattern is actually put out, they only look at the markings on the glass. In other words, you could take a LHD light, convert it to RHD and it would be legal. But taking a RHD and converting to LHD would be illegal, even though that puts out the correct light pattern.Pajerist wrote:There is no sense to convert RHD to LHD headlights from UK, because they E-coded for RHD cars.
Good luck,
Bureaucracy <insert rant here>
- loki
didn't the L400 get sold in LHD anywhere? germany, france, anywhere?
- MardyDelica
yes, they do have for newer on eno problem. but for the older L400 first generation they dont have without e-mark.
do expensive to do so i will just do modification now to pass it.
cheers;
mardy
cheers;
mardy
