Your sounds like to much alcohol in your mix, If you don't see a drop in EGT's at all it means your at the edge the water can offset the methanol. That knocking sound is like when you run to much propane injection in a diesel You need to always start out low like 20% don't go right for a 50/50 mix.shaun wrote:Hey there.
I just put in a pre/turbo 1gph nozzle.felt a slight difference.I then put in a 2gph after turbo instead of the 1gph.Felt increase in power,exhaust temp stayed the same.With the 2gph i have noticed more engine noise,rattle.Sort of sounds like my 3/4 ton dodge.Is this normal?
I am using washer fluid -40c.When I used 50/50 meth. water mix,my exhaust temp went up to 1200F after turbo.
When I was first using the 1gph after turbo only,no pre/turbo,I felt no increase in power.It took about 4 weeks then more power came out.Also my oil stayes cleaner longer.
I have my switch to turn on at 13psi,power is from 3600-4200 rpm.
Max boost is 14.5 psi.I have also advanced my injection timing by 1mm on then bottom mounting flange.
Sorry did not see page 10 until just now. Also one more thing, the line you have your pressure switch connected to would you use the same line for your boost gauge? Just making sure it's a good activation spot even though you guys most likely hooked it up in the same spot just got to check to rule it out.delicat wrote:Guamdoc, I guess you didn't read my post on p.10 explaining what was done... But I just went back and purged it again, this time right at the nozzle like you suggested and it's pouring which means the system should be working. I'm going for a ride right now, if I don't see any difference than we'll "chat" again...
Guamdoc;guamdoc wrote:The purge process is different for the dual nozzle system it's not at the nozzle holder because the check valve is not part of the assembly there. Always purge right before the check valve then give it a quick squirt with the whole system hooked up.
