Is there another L400 in Calgary?
Pacific JDM Parts
Re: Is there another L400 in Calgary?
Post by Pacific JDM Parts »
Clunking in the rear on L400's going over bumps is normally excess play in the rear sway bar links and rear sway bar bushes.Just grab the rear sway bar and see if there is any movement up and down on both sides.
Hope this helps to put an end to you going crazy!!!!
aclarker
Vehicle: L400 Super Exceed
Post by aclarker »
Hope not. The Clunk started to happen post Pro Active... Maybe, I'll get up on a hoist and take a look.
madmazda
Vehicle: 1994 l400
Post by madmazda »
well i live in calgary and am going to be a new owner of a delica spacegear really soon...... I'm hoping I can find a block heater.... hopefully an in line one will do the trick
Erebus
Vehicle: 1992 Super Exceed
Post by Erebus »
madmazda wrote:well i live in calgary and am going to be a new owner of a delica spacegear really soon...... I'm hoping I can find a block heater.... hopefully an in line one will do the trick
In-line heaters suck compared to block heaters. Don't bother with an in-line, waste of money. Block heater is the way to go.
Post by Green1 »
talk to mardy, he's now done a block heater on my new L400, so I'm sure he can give you pointers on how to install one...
DelicaFreaka
Vehicle: 94 L400 4M40
Post by DelicaFreaka »
Here, check this out. It is a fairly simple install if you know your way around some simple tools. I will be doing mine shortly. Just remember that after you drain the rad and pull the line off the rear heater unit you will still have some coolant gush from the right rear frost plug when you bang it out. Put a tarp down to catch or stuff some towels under the plug to soak most of it up as it comes out. A little tight to get at but definitely can be done. No lifting of the vehicle required. Good luck...........................Kirk out.
****Block Heater Part # (found at Lordco) 3100049..... $35.00 ****
http://www.delica.ca/forum/block-heater ... -6592.html
********** Starship Delica **********
"To boldly go where no man has gone before"
