the dream was a small portable WVO filtration system.
it would run on 12volts, and be the size of a small suitcase...
am i dreaming?
maybe... maybe not...
it began with a pump i got from princess auto. actually i got all the parts from PA.
then began the quest for the rest of the system...
parts list:
1. Diesel Pump - 12V
2. Goldenrod 10micron filter 3/4"NPT fittings.
3. Various 3/4" NPT fittings
4. Hoses & Nozzle
5. Piece of Plywood 1/2" 12"x12" square
6. fasteners
7. metal hangers
8. trailer electrical adapter
9. male/female trailer couplers
tools.
1. screwdriver set
2. drill
3. jigsaw
4. cresent wrench
5. hole saw
6. soldering iron or crimp fittings
7. crimper
8. fish tape
1. Cut out the 12"x12" plywood base. you can use a hole saw to drill out a top handle. use a jigsaw to cut it out.
2. Attatch hanging hooks to the back of the board.
3. Dissasemble the pump from the housing, and bolt the housing to the backer board.
4. connect the Goldenrod filter to the pump. for me this was the hardest part... sourcing the fittings. the guys in the hydraulic section of PA were the best.
5. reassemble the pump back into the housing.
then came the electrical. i didnt want to have to open my hood every time i wanted to use the pump so i decided to use a male/female trailer fittings...
6. find a suitable place for the female trailer recepticle and drill hole.
7. Run wiring for trailer 5 to 6 wire adapter, signal lights, power, and ground.
8. INstert Female socket.
9. wire up the male plug to the pump. make sure you mount fuses close to the battery as possible.
10. Connect your hoses and nozzle.
and finally...
Hang your WVO filtration pump on your rear ladder, plug in and enjoy!
big thanks to TardisDeli Jay for all his help. the guy is truely an electrical wizard!
more pics and performance reviews to follow...
