Are there any members out there parting vans?? Please pm details.
Thanks.
Tiny
Moderators: delicanuck, mark
Whenever we got this kind of article from delica owners in remote area, we are thinking about making built-in( plug-in ) system ( of course , from our own control system ) to replace a broken Mitsubishi unit ( It cost around $1200 from part importers ) at a reasonable price.Tinytoy wrote:Hope someone can help you out.
Everyone seems to be hush- hush on how to troubleshoot these.
Like to thank John for trying to help the garage that is working on my van by supplying an ECU, but it was not compatible.
Hope we can get some help from someone on how to get this going. I am quite aware that the other shops in B.C have put allot of time in figuring out how these work
If we can get a schematic for the ECU I might be able to get mine fixed. If this happens I will gladly share the info on where to get them fixed.
Eric
I think we need to follow in facebooks footsteps and have a "like" button on hereccautos wrote:I would strip out all the interior, wiring and maybe the engine. Remove the transmission and suspension, maybe the glass also. Sell the remaining body shell and all the removed components then go out and buy a mercedes with the money gained from selling your Delica in pieces. That would cure the starting problem and install a mercedes glow plug system at the same time
If you had your daily driver sitting at a shop for over a month you would be antsy too.nxski wrote:I think we need to follow in facebooks footsteps and have a "like" button on hereccautos wrote:I would strip out all the interior, wiring and maybe the engine. Remove the transmission and suspension, maybe the glass also. Sell the remaining body shell and all the removed components then go out and buy a mercedes with the money gained from selling your Delica in pieces. That would cure the starting problem and install a mercedes glow plug system at the same time
http://vancouver.en.craigslist.ca/pml/c ... 74978.html
Why not just get one from CCAutos and install that one. He said in a post above that they have them in stock for $150. Not sure what the issue is. Shipping shouldn't be much.Tinytoy wrote:If you had your daily driver sitting at a shop for over a month you would be antsy too.nxski wrote:I think we need to follow in facebooks footsteps and have a "like" button on hereccautos wrote:I would strip out all the interior, wiring and maybe the engine. Remove the transmission and suspension, maybe the glass also. Sell the remaining body shell and all the removed components then go out and buy a mercedes with the money gained from selling your Delica in pieces. That would cure the starting problem and install a mercedes glow plug system at the same time
The shop also said they were in contact with you. I Just want my flipping van back
