hello
my gate lock / unlock switch only unlock's and don't tell anybody but i keep my work tools back there and it sure would be nice to be able to flick that switch to make sure my back gate is locked, has anybody out there fixed this problem or have any idea's ?
thanks....bryan
gate lock switch
- niekt
- Vehicle: L300 4x4 2,5 TD
Re: gate lock switch
Can you lock it with the key or doesn't that work either ?
Niek
2001 L300 4x4 2,5 TD
Weird, my switch only locks, it won't unlock. I have to use the key to unlock from the back. I always assumed it wouldn't unlock for saftey reasons, maybe there's an easy fix for both our problems.
- mdrive
I would open the door pad and test the actuator but connecting wires manually and reversing to check if the actuator opens or cloese. you can always buy another cheap actuator (aftermarket) and add it with a bracket. I just fixed a door lock in toyota hiace.
- ccautos
- Vehicle: 92 Delica SE
There is a wiring harness that runs between the roof and tailgate on the right side of the vehicle and the wires inside go brittle and break with continuous use . Simply pull back the rubber boot and reconnect the broken wires inside .
