Well I've managed to gather all my parts to install a RHD 2-gauge pillar pod. I'm wanting info on running the wires and tube (Boost) down the window pillar.
Anyone of there know of some pics or have instructions ?
Hi I just ordered a similar pillar off ebay. In the meantime I have installed and wired my boost and pyro. As for power for the pyro, I found an unused plug behind the glovebox which has one terminal switched for 12V. Using a spade crimp connection I have robbed the source from there. The ground is attached to a chassis bolt in the same neighborhood. I teed into the light dimmer for the lighting power but it works in reverse to the dash lights so for now I just used the same power source as the pyro power. This means lighting at all times but for now this is something I can live with. A note, I bulb and green condom supplied sucks...I purchased 2 autometer brand LED replacement bulbs for 12 a piece at lordco and they are quite an improvement.
Rick
