When i turn key to start engine i jus hear thinythiny click :)
Whats happend? :)
Starter/Alternator died??
- L300Foca
- Vehicle: Mitshubishi L300 2.5 TD GLX
FollowMe
ubernub
- Vehicle: Mitsubishi L300 2.5TD
Re: Starter/Alternator died??
Check the battery voltage, if its low, the starter wont be able to kick in!
- L300Foca
Battery is new :)ubernub wrote:Check the battery voltage, if its low, the starter wont be able to kick in!
FollowMe
yojimbo
Then it may not be charging, whats the voltage across it while the engine is running, and while it's not?
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
- shealy
- Vehicle: 92 Delica Exceed
Are you getting any power at all from the battery (do the interior lights still come on and glow plugs work etc.)? If so I had this issue happen the other week. Try turning the key to where you can shift, hold your food on the break and shift through all the gears (p to n, back to park. P to r back to park etc.). Then try starting again. Worked for me. Good luck!
- L300Foca
Re:
I will try that :)shealy wrote:Are you getting any power at all from the battery (do the interior lights still come on and glow plugs work etc.)? If so I had this issue happen the other week. Try turning the key to where you can shift, hold your food on the break and shift through all the gears (p to n, back to park. P to r back to park etc.). Then try starting again. Worked for me. Good luck!
As well, my alternator is ok, STARTER is like click click :)
FollowMe
