Hi,
My belts broke for both the alternator and A/C compressor so i went to Parts Source and got a bunch of different lengths until I found a good replacement.
Alternator Belt - GatorBack - 15396 x 2 (UPC Code 037256013669) : 11AV0990
A/C - GatorBack - 15371 x 1 (UPC Code 037256013614) : 11AV0925
This is how the belt looks like
http://www.goodyearep.com/ProductsDetail.aspx?id=11752
all cost just over $30 (both are made by Goodyear)
Hope this helps others needing replacement. This might be similar to the Delicas 2.8 but I cannot guarantee
cheers,
Ryan
Pajero 2.8 Belt replacement
- kpsxtyone
- Vehicle: 94 Exceed Pajero LWB
- Vehicle: Always changing for me
Re: Pajero 2.8 Belt replacement
Good information for other owners, thanks for sharing.
William - JDM Connection inc.
http://jdmconnection.ca/
- deli1733
Thanks i need to get a A/C belt for my pajero, are those part numbers from lordco?
- kpsxtyone
updated the post with the UPC Code and few more numbers from the box
found the website too.
- kpsxtyone
I just got the PN numbers off the packaging. Maybe check with partsource if they can cross reference with lordco?deli1733 wrote:Thanks i need to get a A/C belt for my pajero, are those part numbers from lordco?
Thanks for the leg-work. Those look much much better than the asian parts available through some of our dealers.
Somewhat on topic.. how do you double check your belt tension after installing? It runs fine, just want to be sure.
Thanks.
Thanks.
