4M41 vs 4M40
- Mr. Flibble
4M41 vs 4M40
Has anyone seen the 4M41 engine?
http://en.wikipedia.org/wiki/Mitsubishi_4M4_engine
The reason I ask, is that we seem to be going through a good deal of work trying to get the 4M40 engines to put out more power, and it seems as if there is a 4M41 that has a lot more oomph out there. I have not heard of anyone with a Delica/Pajero with one in Canada, nor do I even know if one is available.
Sounds like it would be a good engine for something like the Super Exceeded project...
Re: 4M41 vs 4M40
Have to wait another 3 years before it comes in the Paj.
				roadie
 - Vehicle: deli L400
Re: 4M41 vs 4M40
My wife's delica has the timing advanced and it helps alot.  Yesterday I turned up the pump on my Pajero and the difference is very noticable.  There is alot more you can do (intake/exhaust/electric rad fan) that will add to those gains....For the size/purpose of the vehicle, the 4M40 can be adjusted to suit your needs....
						- 1994delicaman
 - Vehicle: KTM
Re: 4M41 vs 4M40
Can't you just buy the engine separate?
2006 smart car diesel CDI
2011 KTM 990 Adventure
2015 Mercedes GLK250 Bluetec
2018 KTM Superduke 1290 R
- Mr. Flibble
Re: 4M41 vs 4M40
That's what I was wondering as well!1994delicaman wrote:Can't you just buy the engine separate?
						- MardyDelica
Re: 4M41 vs 4M40
Hi,
yes, i did seen this 4m41 engine thru a mitsubishi strada.
its a crdi engine electronic engine.
wow lots of horsepower, no smoke runs like a V6 engine;
totally diff the 4m40, but same 4 cyl.
did drive on it but wow really fast and strong.test drive this in the phils last march of 2011
i can order thsi engine if anybody wants it. but need th computer on this one also as this is a crdi engine system.
cheer;s
cheer;s
						- Mr. Flibble
Re: 4M41 vs 4M40
I saw something that suggested you had to change the transmission as well to get the 4m41 installed as well.
						- MardyDelica
Re: 4M41 vs 4M40
well i think so.
when i was there it goes to diff type vehicle:
mitsubishi strada and mitsubishi montero:
i thinkw e can get this
cheer;s
cheer;s
						- Mr. Flibble
Re: 4M41 vs 4M40
Well, if I get my letter of compliance so that I may import my Delica into the US, I might just go for this in the future.
It seems that no one else has done it. The reason you need to port over the transmission and all the electrics is that the ECU won't interface with all the Delica components. So, while hardware wise it is a simple and direct swap into the Delica, electronics wise, it is apparently an nightmare. This is according to the Oz crew.
So far, no one has done it to date with a Delica to my knowledge. A pajero has been done.
						- patriceboivin
 - Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=23122
 - Vehicle: Mitsubishi Delica L400 Super Exceed
- Big-Bird
 - Vehicle: 96 PE8W Spacegear
Re: 4M41 vs 4M40
The only a few ways to get your hands on a 4M41:
1: Buy the JDM Pajero that it comes in which may or may not be within the 15 year age limit....I think it has another year to go.....not sure.
OR:
2: Buy a front clip off a wrecked Pajero with the 4M41...that way you get the tranny and the entire fuel management system. And yes you can buy a front clip from japan that is less than 15 years because the IMPORT rules only apply to complete cars.
I have poked around to see if the stock 4M40 could be stroked into a 3.2L...and yes its possible but the 16 valve head off the 4M41 may not fit a stock 4M40 block. So if you kept the stock 4M40 head the engine would probably be starved for air....which means bigger turbo...or god forbid small dual turbos! And what about the stock fuel system on the 4M40..Could the fuel pressure be boosted enough to feed a stroked 4M40 or would a injector change fix that concern?
There are subtle differences between a Delica and the Pajero 2.8 power plants.
The oil dip sticks are in different locations. (I seem to recall that the oil pick up tubes are also different).
The Pajero engine generates a tad more heat than its Delica counterpart....check out the rads guys..Paj is thicker and the thermostats have different temp ranges.
The 4M41 has been called a freight train of an engine because of the power this monster generates and most of that, at least according to a few automotive journals I have thumbed through, has a lot to do with the computer/variable timing and fuel sytem that Mitsu felt they just had to install on the venerable motor.....
(wah!!!! Why didn't the Delica D5 get this instead of the 2.4 diesel they slapped into the D5?)
OR:
				vstrom
Re: 4M41 vs 4M40
When one of you guys attempts the switch, Ill take your 4m40 off your hands.
Maybe try stuffing it into my 300!
Re: 4M41 vs 4M40
I've heard that they don't fit. Having said that I haven't tried. I'll bet VR Trooper could make it fit! It'd be cool to see the 4M40 and the 4D56T together on mounts, so you could walk around them and compare them.vstrom wrote:When one of you guys attempts the switch, Ill take your 4m40 off your hands.
- 1994delicaman
 - Vehicle: KTM
Re: 4M41 vs 4M40
Id like to put a Mercedes OM648 in a L400, 200hp and 500nm's of common rail goodness!
