Hi All,
Looking for a steering rack as mine has a minor leak (will add Lucas to stop) as Butch from CVI thinks mine may be affecting the alignment and pulling to the right.
Would used be a good alternative or is it recommended to buy new?
Joe
L400 steering rack
- joedelica
- Vehicle: 95 Exceed XR The Sapporo Can
Re: L400 steering rack
buy new
it's a pain to replace
- Vehicle: L400
Mine leaks a drip here and there ,is there a kit to rebuild the seals?
- Vehicle: Mitsubishi L300 GLX
I also I need a rebuild kit for steering box .. nobody knows anything?
- Vehicle: 1994 L400 SE
My gearbox also leaks fairly bad. It must be a common occurrence as I was prepared to purchase one just before the one I owned and it too was a leaker. I will eventually get close enough to give it a wipe and visual whether it is a common lip seal or something alien.
Rick
Rick
I hope this can help: the mitsubishi part number of steering box is MB412806
just bought a steering box of a hyundai H100 .. is the same (I hope) .. I will let you know
