Garage sale
- rezdiver
- Vehicle: 1991 L300
Garage sale
cleaning out the garage, everything from deli parts, winch parts, trailer, lightforce lights, and even the bathtub
located in the comox valley
Reza
1991 Delica L300
http://www.iltisforum.com/
Reza
1991 Delica L300
- rezdiver
Re: Garage sale
more things added, including a racor fuel filter water separator
Reza
1991 Delica L300
Reza
1991 Delica L300
- rezdiver
Re: Garage sale
lots more gear added to the list including a small vacuum pump that everyone is using for making the supersuckers for WVO.
Reza
1991 Delica L300
Reza
1991 Delica L300
- rezdiver
Re: Garage sale
offers?
Reza
1991 Delica L300
Reza
1991 Delica L300
Re: Garage sale
You may have already done this, but I have far more luck selling Delica parts on Craigslist than on the forum.
- rezdiver
Re: Garage sale
all over the place, but some of the stuff would be in better hands here if anyone was interested. not too many people need a vacuum pump on craigslist to make a super sucker for their WVO
Reza
1991 Delica L300
Reza
1991 Delica L300
- after oil
Re: Garage sale
im curious about the vacuum pump but it isnt clear to me how to use a vacuum pump to pump wvo? can i use it to somehow pump wvo UP from my settling tank to my gravity feed tank (for feeding centrifuge)
- rezdiver
Re: Garage sale
look here:
http://www.murphysmachines.com/supersuckerpump.html
http://www.murphysmachines.com/how_to/h ... t_wvo.html
you use a solid tank that will not deform or collapse, create a vacuum in it using the vacuum pump. close the valve, drop the hose into the tank or filter system you are sucking from, open valve, and the vacuum created from your tank will suck up till the tank is full.
lots of info on google, great way to do it, and you dont need a pump that will get clogged and need servicing.
Reza
1991 Delica L300
Reza
1991 Delica L300
- after oil
Re: Garage sale
would this be appropriate to suck oil into a 500L home heating oil tank? a 55 gallon steel drum?
sorry for getting off topic of the intent of the original post, but hey, it bumps your garage sale.
- rezdiver
Re: Garage sale
a lot of guys use 55 gallon drums. you will have to research for yourself as i cant say for sure, but if you can get your home heating tank to be fully sealed i am sure it would work although it would probably take a while to get a vacuum in that big of a tank, it may slightly deform the sides of the tank depending on where they put the weld seam but it should work.
Reza
1991 Delica L300
Reza
1991 Delica L300
