Door seals
Door seals
Anyone know if you can get new doors deals? I have a bad wind whistle on the highway and I can see the door buffeting in the wind.
I would rather wear out then rust away.
- Vehicle: 1992 Toyota Hilux 2.8 Quad Cab
Re: Door seals
I have the same whistle from about 80kph and up coming from the drivers side door.
I put petrolium jelly on the door seal and it has definatly help quiet the whistle, give that a try for the time being. Your issue sounds slightly more serious than mine though, I can't see any door movement.
Good luck, if you find replacent door seals let us know!
Ryan
Ryan
- Vehicle: 89 Mitsu Van/Wagon LS X2
Re: Door seals
I have a similar issue with the doors moving. It is caused by the doors sagging. I was able to correct it by re-aligning the doors. You have to pull off the little "fender" pieces to access the bolts for the top door hinges. If you try this, make sure you have some around to help. The door are surprising heavy. I have a few pictures on my phone. I will post them, if can get them off the phone.
- patty
- Vehicle: delica chamonix
Re: Door seals
when my tire fell off it got coaght by my door first which screwed the door.Now it doesnt close properly(thats why my buzzer is always sounding) but i also have the rattle in it with the constant wind whistle, and just today i noticed a leak of water at the front of the door.so ill have to do somethuing about that soon.
Re: Door seals
Call a U.S. Mitsubishi dealer, ask for the door seals for a 1990 Mitsubishi van/wagon, get the part # from them, order through your local Canadian Mitsubishi dealer. Please post the # when you get it.
- mdrive
Re: Door seals
MB421471 Run channel,front glass
MB421503 Weather strip, front door ,LH
MB416674 Pad,rear door glass
MB416313 Run channel, rear door glass,LH
MB416314 Run channel,rear door glass,RH
MB416393 Weather strip,quarter glass
MB421504 Weather strip,front door,RH
- Vehicle: 1992 Exceed
Re: Door seals
Which seals are for the lower rubber outside passenger/drivers windows? The upper window channels of passenger/drivers windows? And the lower inside fabric lined passenger/driver window seal?
_____________________________
1992 Delica Exceed (Mostly Stock)
2003 VW Jetta TDI
2003 VW Jetta TDI
