1993 Chamonix Rear trunk latch
lito_onion
- Vehicle: 1993 Delica Chamonix
The latch seems to be all fouled up and won't hold the trunk closed. Does anyone have a latch they could sell or know any other models that would have the exact same latch? (I'm guessing all of the 3rd gen Delicas will)
thelazygreenfox
Re: 1993 Chamonix Rear trunk latch
Try loosening the latch and repositioning it a little. It usually doesn't take much to realign it with the tailgate. Look at the latch for marks and move it the opposite direction for a better fit.
good luck
TLWF.
good luck
TLWF.
lito_onion
I managed to fix the problem! I sprayed the internals alternatively with brake cleaner and WD40, and forced the moving parts with a pair of pliers. After about a dozen rinses, the part moved - and after a dozen more, it moved smoothly. The latch was reinstalled without a problem.
