How can I repair my Crystal lite power sunshades?
gali
Vehicle: Delica Turbodiesel 1991
Post by gali »
Hi Everybody,
I have a bit of a problem with the old Delica. The Crystal lite power shades don't work. By pressing the button, I can hear that the motor is still working, but the shades aren't moving and stay rolled up.
After searching this forum, I have been unable to find any detailed instructions on how to repair the shade.
Can anybody provide me with both basic information on the way the power-shade functions and how I can repair it.
Thanks a bunch,
-Gali
nxski
Re: How can I repair my Crystal lite power sunshades?
Post by nxski »
Sounds like it could be as simple as them being jammed. That happened to one of mine and I just pulled on it manually while using the switch and it came out no problem. They can get stuck if you hold the button down to long...
gali wrote:After searching this forum, I have been unable to find any detailed instructions on how to repair the shade.
This is what I found. Does it help ?
I haven't worked on the sunshades for a long time but the clips are usually the culprits if the motor is still working.
http://www.delica.ca/forum/sunshade-rep ... o-766.html
http://www.delica.ca/forum/crystsal-lit ... -9084.html
nvanadm
Post by nvanadm »
gali wrote:The Crystal lite power shades don't work.
Hi, a little more info may be useful as well.
You say they don't work, have they EVER worked for you and just stopped now, or did you just acquire the delica and they don't work?
And by shades (plural), i'm assuming all 4 are not working? Or just 1 or 2?
Thanks.
RichD
Post by RichD »
If they are all stuck open, what's the problem?
The only time I've ever closed them was to demonstrate that they work.
Richard Dagenais
gali
Post by gali »
Thanks for your help. After investigating the shade mechanism I found out that the both plastic clips that fixes the end of the blends with rod are broken. I've already known the how-to with the metal strip, but I would prefer a simpler solution.
Has anybody tried the fix this with earth magnets? Although this is only a manual fix, it would be the most elegant way for me but I can't imagine that this would work with the heavy rolling mechanism.
